LazyUpgradeStatus Migration fails with "Could not create constraint or index" error due to duplicate data in SolarWinds Platform 2025.4
This article provides guidance to identify and resolve common errors encountered during data migration.
10/21/2025 12:00 PM
10/21/2025 12:00 PM
Data migration may fail with an error similar to the below:
A screenshot of a computerAI-generated content may be incorrect.
dbm_Migrate2Partitioned: Could not create constraint or index. See previous errors.
ALTER TABLE APM_HardwareItem_CS_stg WITH CHECK ADD CONSTRAINT CHK_APM_HardwareItem_CS_stg CHECK ([Timestamp] >= '20250427' AND [Timestamp] < '20250428')
Orion Platform
Please note the following for each query below:
  1. Connect to the SQL server and open SQL Server Management Studio.
  2. Log in to SSMS with SQL Admin credentials.
  3. Take a backup of the SolarWinds Platform database.
  4. Open a new query window, paste the query below, and select Execute query:
WITH dupl AS (
SELECT detail.*,
ROW_NUMBER() OVER (PARTITION BY [Timestamp], HardwareItemID ORDER BY [Timestamp] DESC) AS rnk
FROM APM_HardwareItem_CS_Detail_hist detail
DELETE FROM dupl WHERE rnk > 1;
  1. Verify if the above query works by executing below query:
WITH dupl AS (
SELECT detail.*,
SELECT * FROM dupl WHERE rnk > 1;
It should return zero rows.
  1. Open a new query window and run this query:
Select * from LazyUpgradeStatus where Tablename LIKE 'APM_HardwareItem%' and Granularity = 1
Here, EndDateUTC column value should not be NULL.
  1. Users can go to the web console, click on the Notification and if no records are listed on the table, the migration has been completed. The notification will be cleared the next day.
If the same error is observed for "Wireless_clients" as shown below:
ALTER TABLE Wireless_Clients_CS_stg WITH CHECK ADD CONSTRAINT CHK_ Wireless_Clients _CS_stg  CHECK ([Timestamp] >= '20250427' AND [Timestamp] < '20250428')
WITH dupl AS (
SELECT detail.*,
ROW_NUMBER() OVER (PARTITION BY [Timestamp], NodeID, [Index] ORDER BY [Timestamp] DESC) AS rnk
FROM Wireless_Clients_CS_Detail_hist detail
WITH dupl AS (
SELECT detail.*,
Select * from LazyUpgradeStatus where Tablename LIKE 'Wireless_Clients%' and Granularity = 1
If the same error is observed for "APM_ComponentStatus" as shown below:
ALTER TABLE APM_ComponentStatus_CS_stg WITH CHECK ADD CONSTRAINT CHK_ APM_ComponentStatus _CS_stg  CHECK ([Timestamp] >= '20250427' AND [Timestamp] < '20250428')
WITH dupl AS (
SELECT detail.*,
ROW_NUMBER() OVER (PARTITION BY [Timestamp], ComponentID, [Availability] ORDER BY [Timestamp]
DESC) AS rnk
FROM APM_Componentstatus_cs_Detail_hist detail
WITH dupl AS (
SELECT detail.*,
DESC) AS rnk
Select * from LazyUpgradeStatus where Tablename LIKE 'APM_Componentstatus%' and Granularity = 1
  1. Users can go to the web console, click on the Notification and if no records are listed on the table, it implies that migration has been completed. Notification will be cleared the next day.
