Security Compliance
SEM reboot for troubleshooting
This article provides guidance about when to reboot SEM. Rebooting SEM rarely fixes problems, but it can delay figuring out why a reboot was needed to begin with.
- Sudden burst of events
- Low resource allocation.
- Mis-configured rules / Alerts
- Underlying Infrastructure issues
SEM is a Linux-based hardened-appliance that has been virtualized. Common misconception: Rebooting SEM fixes issues.
Fact: A reboot rarely fixes any problem, but may delay getting to the cause for why the reboot was considered.
A reboot will do the following:
- Clear out cached log data.
- Re-connect all agents after it starts up.
A reboot may be required when all other troubleshooting has failed, or recommended by SolarWinds Support.
Otherwise, if you changed the hostname, changed the network configurations, or imported a "backupconfig" (used for migrating to different VM platform, disaster recovery testing, or to restore the rules/groups).
