Security Compliance
SEM mount error (115): Operation now in progress
This article describes some steps and checks to avoid/circumvent the error mount error (115): Operation now in progress.
This article describes an error during the Security Event Manager (formerly Log & Event Manager) upgrade process where you are asked to specify a network share location containing upgrade files. After entering the network share as \\hostname\sharename and the username and password, SEM throws the error below and the upgrade process fails.
Mount error(115): Operation now in progress
- A network name resolution failing on the smb client in SEM
- SMB v1 is disabled on the network share machine (windows)
Solution 1:
- Check ICMP connectivity (ping) between the hosts.
- Verify no Routing/Firewall ACL issue between the hosts if they are in different networks.
- Attempt to mount a share on the same subnet as SEM.
- Attempt to use the IP address and a simple share name when mounting the share.
- e.g. \\10.1.1.1\sem\ rather than \\some_host_some_place_on_the_network\this_share.name_desktop_special_unique_and_long
If you are getting a different mount error please check relevant KB's for solution/workaround(s).
On Windows 2008 and 7 upwards you can run the powershell command "get-smbconnect" to view the client version details.
- Check for default supported version of smb clients version at MS website (© 2018 Microsoft, available at https://blogs.technet.microsoft.com/josebda/2013/10/02/windows-server-2012-r2-which-version-of-the-smb-protocol-smb-1-0-smb-2-0-smb-2-1-smb-3-0-or-smb-3-02-are-you-using/, obtained on December 17, 2018).
- And how to enable specific SMB version (© 2018 Microsoft, available at https://support.microsoft.com/en-ie/help/2696547/how-to-detect-enable-and-disable-smbv1-smbv2-and-smbv3-in-windows-and, obtained on December 17, 2018).
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
