Security Compliance
LEM monitored via NPM
This article details information on monitoring older versions of LEM using NPM. (Prior to LEM version 6.3.1)
10/10/2018 2:20 PM
10/10/2018 2:20 PM
Log & Event Manager
Prior to LEM 6.3.1, it was not a feature of LEM that it could be added into NPM for monitoring via SNMP. It could only be added as an ICMP node. As an alternative, it was suggested to monitor the VM itself.
Please keep in mind, LEM has internal monitoring, it makes sure that the logs/data is not going above 90%. If there are any issues with space, then internal warnings and emails may be triggered.
If you review the LEM rules, you will find that there are out of the box rules that are for monitoring LEM. If they are not enabled yet, you can then enable those which are required, adjusting and tailoring to your requirements.
LEM 6.3.1 onwards allows LEM to be polled via SNMPv3, please see Monitor SNMP traps for details to enable this.
For more details on the changes in LEM 6.3.1 please see the release notes LEM monitored via NPM.
