Security Compliance
SEM fails to boot after a file system check or prompts to press Ctrl-D to continue
SEM is failing to boot after it completes a file system check and may prompt you to press Ctrl-D to continue.
Security Event Manager (formerly Log & Event Manager) is failing to boot after it completes a file system check and may prompt you to press Ctrl-D to continue.
- Press Ctrl-D to continue if prompted.
- When SEM finishes booting, go to Advanced Configuration > appliance > reboot.
- While SEM is rebooting, observe if SEM performs another file system check or reprompts for Ctrl-D.
- If it reboots without a file system check, it repaired itself successfully and no further action is needed.
- If it performs another file system check, contact SolarWinds Support.
