Security Compliance
SEM reports and Sophos Enterprise Console
This article describes a known issue where the SEM reports console won't run reports on a system with Sophos Enterprise Console also installed.
This article describes a known issue where the Security Event Manager (formerly Log & Event Manager) reports console won't run reports on a system with Sophos Enterprise Console also installed. In this scenario, the crystaljrc.log log (located in "%ProgramFiles%\SolarWinds SEM Event Manager Reports" by default) shows errors such as:
13 Dec 2941 12:05:12 [ORBacus:ThreadPerRequest:Dispatcher] FATAL com.crystaldecisions.data.jdbc - Return DbErr_TableNotFound in DbFetchTableInfoEx()
13 Dec 2941 12:05:12 [ORBacus:ThreadPerRequest:Dispatcher] FATAL com.crystaldecisions.data.javaserver - Return error value in dispatcher's DbFetchTableInfoEx(). The error code is: 21
