Security Compliance
SEM File Audit Failures filter conditions
This article shows the default conditions used for the File Audit Failures filter under the Security section.
10/31/2018 7:30 PM
10/31/2018 7:30 PM
This article applies to Security Event Manager (formerly Log & Event Manager).
This article provides the default conditions used for the File Audit Failures filter under the Security section.
Name: File Audit Failures
Conditions:
FileAuditFailure.FileName != *desktop.ini
See the Default SEM filter conditions on the Web Console Monitor page  page article for a full list of available default filters in SEM.
