Security Compliance
SEM Desktop Console installation error: The application cannot be installed due to a certificate problem
When upgrading or installing your Adobe AIR-based SEM Desktop Console, you receive the following error: Sorry, an error has occurred. The application cannot be installed due to a certificate problem. The certificate does not match the installed application certificate, does not support application upgrades, or is invalid. Please contact the application author.
10/31/2018 7:20 PM
10/31/2018 7:20 PM
The following error occurs when upgrading or installing Adobe AIR-based Security Event Manager (formerly Log & Event Manager) Desktop Console:
Files from a previous installation or console version are interfering with the new installation.
  1. Uninstall both Adobe AIR and SolarWinds Security Event Manager Console from Programs and Features, if present.
  2. Delete all of the following folders, if present:
    C:\Program Files (x86)\Common Files\Adobe AIR
    C:\Program Files (x86)\SolarWinds Log and Event Manager
    C:\Users\<useraccountname>\AppData\Local\Adobe\AIR
    C:\Users\<useraccountname>\AppData\Roaming\sim.console
  3. Download the latest version of Adobe AIR from Adobe's website and install as normal.
  4. Run and complete the installation for the Desktop Console.
