Tools
Kiwi Syslog Web Access does not come up
This article describes what needs to check when the Kiwi Syslog web access is not loading.
- The UltiDev Web Server Pro service has not started, causing the Web Access to fail to come up.
- The website is being accessed via an insecure HTTP port
- IIS Service is not started in new version 9.8
- Check and make sure the UltiDev Web Server Pro service is started. UltiDev Web Server Pro enables the Web Access to show up and start.
- Kiwi Syslog Web access 1.6.2 requires HTTPS to be accessible. Ensure that SSL is configured and the website is accessed via HTTPS.
- The latest version of Kiwi Web Access v9.8 now uses IIS for its web services. Check if the IIS web services is running
