Tools
Kiwi Syslog Web Access Server error: System.Web.HttpUnhandledException
This article provides steps to resolve the following error on the Kiwi Syslog Web Access after upgrading to 9.6.7.1: Exception of type 'System.Web.HttpUnhandledException' was thrown.
Exception of type 'System.Web.HttpUnhandledException' was thrown. Status Code: 500 System.Web.HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object. at _Event.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e)
- Stop the Kiwi Syslog Server service (see https://support.solarwinds.com/SuccessCenter/s/article/Start-Stop-Kiwi-Syslog-Server?language=en_US).
- Stop the "Kiwi Web Access" site in IIS manager
- Open the following directory:
C:\Program Files (X86)\SolarWinds\Kiwi Syslog Web Access\html\App_Data\
- Move all the Event.sdf files that are saved with
Event#.sdfnaming convention (Event1.sdf,Event2.sdf...) to an alternate location.- Note: Do not move the Systems.SDF and the Event-Blank.sdf files
- Right-click and copy Event-blank.sdf into the same folder.
- Rename the copy to Event.sdf. (Do not rename the original Event-blank.sdf but leave this file in the same folder).
- Start the Kiwi Syslog Server service.
