Tools
Kiwi CatTools - Backup my device config using TFTP
Kiwi CatTools provides an activity called General.Backup Running Config which can use Telnet/SSH to collect config information from devices. The following information provides examples of how Kiwi CatTools can be used to backup devices using TFTP.
General.Backup Running Config which uses Telnet / SSH to collect configuration information from devices. The following article provides examples of how Kiwi CatTools can be used to backup devices using TFTP.Product section
- Create a new
General.Entercommand activity containing one of the following example commands on the Options tab. - Replace the example IP address
192.168.1.200with the IP address of your TFTP Server.
Note: Kiwi CatTools provides a built-in TFTP Server.
Example for Cisco IOS
copy running tftp 192.168.1.200 %ctGroupName/%ctDeviceName.cfg
Example for Cisco CatOS
<nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/> copy config tftp %ctCR 192.168.10.200 %ctCR %ctDeviceName.cfg %ctCR<nowrap/> <nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/>
Alternate command for some CatOS versions
<nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/> write 192.168.1.200 %ctDeviceName.cfg %ctCR<nowrap/><nowrap/><nowrap/> <nowrap/><nowrap/><nowrap/><nowrap/><nowrap/> <nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/><nowrap/>
Note: To send a carriage-return, use the Kiwi CatTools variable %ctCR. See the CatTools help Activities chapter, "General.Enter command" section for more details about the Kiwi CatTools variables.
