Applications Systems
Key differences in monitoring Amazon RDS through DPA
This article overviews what the key differences are when using DPA to monitor Amazon RDS instances
10/18/2018 12:01 PM
10/18/2018 12:01 PM
This article overviews what the key differences are when using DPA to monitor Amazon RDS instances.
Database Performance Analyzer
Amazon RDSSupported VersionsKey Differences
Oracle
11.2
12.1
Unavailable Alerts:
  • Oracle Alert Log Error uses V$DIAG_ALERT_EXT instead of X$DBGALERTEXT
Explain Plans:
  • Explain plans cannot be generated with a SYS account. You must specify a different account to generate the live plan.
Workarounds for not having a SYS.UTL_CON package:
  • To kill a real time session, use RDSADMIN.RDSADMIN_UTIL.KILL.
  • Trace session permissions granted through START_TRACE_IN_SESSION and STOP_TRACE_IN_SESSION
Microsoft SQL Server
2008 SP4
2008 R2 SP3
2012 SP3
2014
2014 SP1
Unavailable Alerts:
  • SQL Server Windows Service Not Running
  • SQL Server Long Running Jobs
  • SQL Server Log Has Many Virtual Logs
  • SQL Server Job Failure
  • SQL Server Error Log Alert
Explain Plans:
  • The DPA monitoring user does not have a sysadmin role and may have limited access to objects. you can specify a different user to generate the live plan before you generate the plan.
WMI-based statistics are not available:
  • CPU Queue Length
  • CPU Utilization
  • Disk Queue Length
  • Memory Paging Rate
  • Memory Utilization
  • Physical I/O Rate
  • Physical Read Rate
  • Physical Write Rate
Workaround for not having a sysadmin role:
  • DPA user is a member of the processadmin role
MySQL
5.6.10 and later
5.7
No differences
You can repoint MySQL but not Oracle or Microsoft SQL Server Instances
It is not possible to transfer a registered Oracle or Microsoft SQL Server database instance between Amazon RDS and a self-managed database, and retain SolarWinds DPA historical data. Any Oracle or Microsoft SQL Server database instance transferred between Amazon RDS and a self-managed instance opens as seperate instances.
MySQL database instances can be repointed. You can continue monitoring where you left off after transferring a database instance between Amazon RDS and self-managed. To repoint, update the connection details of the registered database to point to the new location.
