Applications Systems
JAVA JMX interface vulnerability
This article solves the JAVA JMX interface vulnerability. CVE-2015-2342. The Java Management extensions (JMX) service on this host does not require any authentication. The JMX/RMI service is used to monitor the Java Virtual Machine (JVM), but can also be used to register a new managed bean (MBean) from a remote URL using the "javax.management.loading.MLet" function. Using this function, a remote, unauthenticated attacker can upload and run a JAR file containing arbitrary Java code of the attacked.
10/31/2018 8:06 PM
10/31/2018 8:06 PM
CVE-2015-2342
Virtualization Manager
Details from the vulnerability report:
The Java Management extensions (JMX) service on this host does not require any authentication. The JMX/RMI service is used to monitor the Java Virtual Machine (JVM), but can also be used to register a new managed bean (MBean) from a remote URL using the "javax.management.loading.MLet" function. Using this function, a remote, unauthenticated attacker can upload and run a JAR file containing arbitrary Java code of the attacker's choosing.
Impact:
An attacker can execute arbitrary Java code running with the same privileges as the JMX/RMI process.
Note: This resolution will block the JMX ports in the appliance's firewall. Another option is to just block it elsewhere according to the customer's options.
Log in to the VMAN appliance using SSH and execute the following commands:
sudo iptables -A INPUT -p tcp --dport 1099 -s 127.0.0.0/8 -d 127.0.0.0/8 -j ACCEPT
sudo iptables -A INPUT -p tcp --dport 1099 -j DROP
sudo iptables -A INPUT -p tcp --dport 9004 -s 127.0.0.0/8 -d 127.0.0.0/8 -j ACCEPT
sudo iptables -A INPUT -p tcp --dport 9004 -j DROP
sudo /etc/init.d/iptables save
