Applications Systems
JAVA_HOME environment variable must be set for JMX component monitors
For SAM, the JAVA_HOME environment variable needs to be set for JMX component monitors. If they variable is not set, you may encounter the error "Exception: Unable to determine JAVA_HOME" in the Orion agent's Python logs. To resolve, verify and set the JAVA_HOME environment variable for the server.
11/13/2018 9:29 PM
6/29/2020 4:39 AM
The JAVA_HOME environment variable needs to be set for JMX component monitors. If they variable is not set, you may encounter the error "Exception: Unable to determine JAVA_HOME" in the Orion agent's Python logs. To resolve, verify and set the JAVA_HOME environment variable for the server.
Server Application Monitor
The JAVA_HOME environment variable is not set for the server. When the JMX component monitor runs, the following error occurs in the Orion agent's Python logs:
"Exception: Unable to determine JAVA_HOME".
To resolve, verify and set the JAVA_HOME environment variable for the server. Follow the vendor instructions for checking and adding a variable to the environment.
