Applications Systems
Issue with DPA running on ESX servers with a compatibility setting of ESX 3.4 or 4
DPA running on certain VM environments might not run because of a bug in Java 14.
4/3/2020 4:45 AM
1/30/2025 4:07 PM
If you attempt to run DPA on ESX servers as a virtual machine with a compatibility setting of ESX 3.4 or 4, DPA might not start.
Database Performance Analyzer
Because of a Java 14 bug, a missing avx CPU flag might prevent DPA from starting. For more information about the bugs, see:
(Content provided by OpenJDK, available at https://bugs.openjdk.java.net/,  obtained on March 27, 2020.)
For more information about compatibility, see Virtual Machine Compatibility  (©2020 VMware, Inc, available at https://docs.vmware.com/, obtained on March 27, 2020).
Do one of the following:
  • Update your VM compatibility version to the latest one (for example, 6.7).
  • Upgrade JDK to a version in which the bug is fixed (11.0.8 or 14.0.1).
  • Add -XX:UseAvx=0 property to JAVA_OPTS for your JDK.
