Applications Systems
Browser settings updated by WPM Recorder and WPM Player worker processes
This article lists browser settings that are updated by WPM Recorder and WPM Player worker processes.
The WPM Recorder and WPM Player leverage web browsers (such as Internet Explorer) to play back transactions. To support that functionality, WPM worker processes may modify Windows Registry settings for browser settings, as documented in this article.
Group Policy settings may revert changes made by WPM to browser settings that can stop the WPM Recorder or WPM Player from working. If that occurs, use this information as a reference.
Warning: SolarWinds strongly recommends that you back up your registry before making any edits to your system registry. You should only edit the registry if you are experienced and confident in doing so. Using a registry editor incorrectly can cause serious issues with your operating system, which could require you to reinstall your operating system to correct them. SolarWinds cannot guarantee resolutions to any damage resulting from making registry edits.
| Root Key | Key | Key name | Set value (hex) | TYPE | Delete key |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings | AutoDetect | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings | DisableCachingOfSSLPages | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings | WarnonZoneCrossing | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\CACHE | Persistent | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings | CertificateRevocation | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings | IEHardenIENoWarn | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zonemap | ProxyByPass | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zonemap | IEHarden | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zonemap | UNCAsIntranet | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zonemap | AutoDetect | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2 | {A8A88C49-5EB2-4990-A1A2-0876022C854F} | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2 | {AEBA21FA-782A-4A90-978D-B72164C80120} | Yes | ||
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1 | Flags | 0x43 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1 | 2500 | 0x03 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2 | Flags | 0x47 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2 | MinLevel | 0x10000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | CurrentLevel | 0x11500 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | MinLevel | 0x11000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | RecommendedLevel | 0x11500 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | TemplateIndex | 0x11500 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1001 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1200 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1400 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1402 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1405 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1407 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1409 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1601 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1604 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1605 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1606 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1608 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1609 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1800 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1802 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1803 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1804 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1809 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1A02 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1A03 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1A05 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1C00 | 0x10000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2000 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2001 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2004 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2007 | 0x10000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2100 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2101 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2106 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2300 | 0x01 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2301 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2400 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2401 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2402 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2600 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 2700 | 0x00 | DWord | No |
| HKCU | Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_MAXCONNECTIONSPER1_0SERVER | SolarWinds.SEUM.Recorder.exe | 0x06 | DWord | No |
| HKCU | Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_MAXCONNECTIONSPER1_0SERVER | SolarWinds.SEUM.Legacy.Agent.Worker.exe | 0x06 | DWord | No |
| HKCU | Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_MAXCONNECTIONSPERSERVER | SolarWinds.SEUM.Recorder.exe | 0x06 | DWord | No |
| HKCU | Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_MAXCONNECTIONSPERSERVER | SolarWinds.SEUM.Legacy.Agent.Worker.exe | 0x06 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\1 | 1A00 | 0x00010000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\2 | 1A00 | 0x00010000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3 | 1A00 | 0x00010000 | DWord | No |
| HKCU | Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\4 | 1A00 | 0x00010000 | DWord | No |
