Create an Interface utilization alert for Warning/Critical thresholds in NPM
Receive/Transmit utilization alerts based on different Warning/Critical thresholds for interfaces.
There may be a requirement to set different threshold levels for interfaces and creating separate alerts for each utilization level may not be a feasible solution. With the below alert, Warning/Critical threshold levels for utilization can be defined on the interface level and a single alert can be configured to trigger when the 'Threshold Reached' value is 'True'
- Create an alert
- Define the trigger conditions as shown in the below screenshots
- Customize the alert specific to your requirements, if any.
