Interfaces Type or Name were not filtered in the network discovery auto-import option
This article will provide a workaround on how to filter Interface types or names in automatic import Network Discovery
Interface Name / Type filtering is not working
In this example, you wanted to add an Interface except 'Loopback' interface, however it's not working
Select 'All columns' and fill in your condition or keyword
e.g
This filter should work
