Interface Down Events when end device disconnects
If you are receiving many "Interface Down" Events when monitoring your access ports in UDT and NPM, monitor your access ports/interfaces only in the User Device Tracker. Do not monitor them in the Network Performance Monitor.
10/15/2018 10:56 PM
10/15/2018 10:56 PM
Receiving many "Interface Down" Events due to devices being disconnected from access ports/interfaces.
User Device Tracker
This is due to monitoring all the access ports in NPM and UDT. When an end device is disconnected from the port/interface, the port/interface goes down. If the port/interface is monitored by NPM, an "Interface Down" event will be triggered.
Do not monitor access ports/interfaces in NPM. Only monitor them in UDT.
