Interface Capacity Utilization report
This article describes how to view and produce the Interface Capacity Utilization report.
- Open Orion Web Console and click Report on the Home tab.
- Click Manage Reports.
- Search for Node Capacity Forecast.
- Select the Node Capacity Forecast check box and then click Duplicate and Edit.
- Click Edit Resources.
- Deselect the check box for the following then click Submit.
CPU Load
Percent Memory Usage
Percent Disk Usage
Click Preview and double check if only interfaces are showing. Click Save under the Summary tab.
