Security Compliance
Integrate Cisco network devices with SolarWinds SEM
This article provides several procedures for integrating various types of Cisco devices with the SEM appliance.
10/9/2018 8:56 PM
3/12/2020 10:57 PM
This article covers the different procedures for integrating various types of Cisco devices with the Security Event Manager (formerly Log & Event Manager) appliance.
Integrate Cisco IOS routers and switches with SolarWinds SEM
These steps show how to configure Cisco IOS devices to log to the SEM appliance, and how to configure the Cisco PIX and IOS connector on the SEM manager.
Configure your Cisco IOS routers and switches:
  1. Connect to your Cisco IOS device using an SSH or Telnet client.
  2. Log in using administrative credentials for the device.
  3. Enter enable.
  4. Retype the administrative password for the device.
  5. Enter configure. A message appears asking how you would like to configure. Press Enter.
  6. Enter logging SEM_IP_address.
    LSM_IP_address is the IP address of your SEM manager.
  7. Enter logging facility local2. This defines where the SEM manager for the IOS logs.
  8. Enter logging trap informational, and then enter exit to return to the previous prompt.
    The debug level is used to capture everything during troubleshooting process, but choose the level best suited to your environment.
  9. To reboot the device with the new configuration, enter copy run start.
  10. When prompted about the destination, press Enter.
If you have increased the level of security for the inside ports to secure, this blocks the ASA from syslogging on port 514. You will have to make changes or send logs out of another interface if you want.
Configure the Cisco PIX and IOS connector on your SEM manager:
SEM HTML5 console (versions 6.6 and newer)
  1. In the SEM Events Console, navigate to Nodes > Manager Connectors.
  2. In the search box, enter Cisco.
  3. Select the Cisco PIX and IOS connector, and then click Add Connector.
  4. Enter a new name, or maintain the default.
  5. Verify the log file value which should match the local facility in the Cisco routers and switches process, and then click Add.
  6. Under Configured connectors, select the connector, and then click Start.
SEM Flash console
  1. On the SEM console toolbar, navigate to Manage > Appliances, and log on to the SEM manager where you can configure the connector.
  2. Next to the SEM manager, click the gear icon, and then select Connectors.
  3. In the Connector Configuration window, enter Cisco in the search box at the top of the Refine Results pane.
  4. Next to the Cisco PIX and IOS connector, click the gear icon, and then select New.
  5. Replace the Alias value with a more descriptive tool alias.
  6. Verify the log file value which should match the local facility in the Cisco routers and switches process.
  7. After configuring the connector, click Save.
  8. Next to the new connector, click the gear icon, and then select Start. The Status icon turns green to indicate the connector has started.
  9. To exit the Connector Configuration window, click Close.
Once the connector starts running, you can create a filter to display all traffic from that specific device. For example:
Any Alert.ToolAlias = *IOS Switch 1*
Note: the asterisks serve as wildcard characters.
Integrate Cisco IDS/IPS with SolarWinds SEM
The following steps outlines the procedures in configuring a Cisco IDS/IPS user for integration with the SEM appliance, and configuring the Cisco IDS/IPS connector on the SEM appliance.
Configure Cisco IDS/IPS for integration with the SEM appliance:
Create a View Only user for your IDS/IPS appliance, which the SEM appliance will use to subscribe to the Cisco appliance's log data.
Configure the Cisco IDS/IPS connector on your SEM manager:
  1. On the SEM console toolbar, navigate to Manage > Appliances, and then log in to your SEM manager as an administrator.
  2. Next to your SEM manager, click the gear icon, and then select Connectors.
  3. In the Connector Configuration window, enter Cisco in the search box at the top of the Refine Results pane, and then select IDS and IPS from the Category menu.
  4. Click the gear icon next to the connector that corresponds to the version of Cisco IDS/IPS in your environment, and then select New.
  5. Enter a custom alias, or accept the default.
  6. If you are configuring the Cisco IDS/IPS v5/5.x connector, enter the URL for your IDS/IPS server in the URL field.
  7. If you are configuring the Cisco IPS 5+ (SDEE) connector, enter the IP address or host name for your IDS/IPS server in the Server field.
  8. Enter the username and password for the user created for integration with your SEM appliance.
  9. Once you have configured the connector, click Save.
  10. Next to the new connector (denoted by an icon in the Status column), click the gear icon, and then click Start.
  11. To exit the Connector Configuration window, click Close.
Integrate Cisco PIC and ASA firewalls with SolarWinds SEM
The following steps show how to configure Cisco PIX and ASA firewalls to log to the SEM appliance, and how to configure the Cisco PIX and IOS connector on the SEM manager.
Configure your Cisco PIX or ASA firewall:
  1. Connect to your firewall using an SSH or Telnet client.
  2. Log in using administrative credentials for the firewall.
  3. Enter enable.
  4. Re-enter the administrative password for the firewall.
  5. Enter config term.
  6. Enter logging host inside SEM_IP_address.
    Sem_IP_address is the IP address of your SEM manager.
  7. Enter logging facility 18. This defines where the SEM manager will look for the firewall logs.
  8. Enter logging trap level.
    Note: Choose one of the logging levels listed in the Cisco PIX and ASA Trap Levels table for the levelvalue. You can use either the trap level or code for this value. SolarWinds recommends using the debug logging level. For more information see this article - Integrate Cisco network devices with SolarWinds SEM.
  9. To enable logging with these settings, enter logging on.
  10. To return to the previous prompt, enter exit.
  11. To check that the new configuration is in place after a firewall reboot, enter copy run start.
  1. On the SEM console toolbar, navigate to Manage > Appliances, and then log on to the SEM manager where you can configure the connector.
  5. Replace the alias value with a custom alias, or accept the default. For example, PIX Firewall.
  6. Check to ensure the log file value matches the local facility defined in the Cisco PIX or ASA Firewall procedure.
  7. Once you have configured the connector, click Save.
  8. Next to the new connector, click the gear icon, and then select Start. The Status icon will turn green to indicate the connector has started.
Once the connector starts running, the default Firewall filter will begin displaying alerts from your Cisco PIX or ASA firewall. This connector will receive events from Cisco IOS operating system installed on PIX and ASA firewalls, or switches and routers with the IOS operating system.
Note: The conditions for the default firewall filter read:
 Any Alert.ToolAlias = *Firewall*
The asterisks serve as wildcard characters. If the alias does not contain the word firewall, the default filter will not work until it has been edited to match the alias you defined.
By default, this connector will not receive TCP builds or TCP teardowns. To enable this functionality, see Enable SEM to Track Cisco Firewall NAT Buildup and Teardown Events.
TRAP LEVEL
CODE
DESCRIPTION
Emergency0Forwards only the highest priority messages, usually indicating failure or panic scenarios that must be addressed immediately.
Alert1Forwards messages that require immediate attention.
Critical2Forwards messages that should be reviewed as soon as possible and might be early warning signs of further problems.
Error3Forwards messages that might indicate a problem.
Warning4Forwards messages that should receive attention and might be errors.
Notification5Forwards messages that are considered to be important information, but that are not error conditions.
Informational6Forwards most messages.
Debug7Forwards all messages, including IDS messages.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
