Installed SQL components on an Orion server
This article lists the Microsoft SQL components included on the server when Orion is installed.
10/25/2018 1:15 PM
4/19/2022 7:13 AM
These components are included with the install of Orion and are required for Orion to properly communicate with the SQL database.
Network Performance Monitor
The following SQL components are normally used by Orion:
  • Microsoft SQL Server 2017 T-SQL Language Services
  • Microsoft SQL Server vNext Policies CTP2.0
  • Microsoft SQL Server 2008 Native Client
  • Microsoft SQL Server 2012 Management Objects
  • Microsoft SQL Server 2012 Management Object (x64)
  • Microsoft SQL Server 2012 Native Client
  • Microsoft SQL Server 2014 Management Objects
  • Microsoft SQL Server Compact 3.5 SP2 ENU
  • Microsoft SQL Server Compact 3.5 SP2 x64 ENU
  • Microsoft SQL Server Data-Tier Application Framework
  • Microsoft SQL Server Management Studio - 17.1
  • Microsoft SQL Server vNext CTP2.0
Screenshots property of © 2017 Microsoft.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
