Applications Systems
Installation process stuck in NPcap installation.
During the upgrade process or installation process got stuck while installing NPcap.
9/18/2020 5:21 PM
1/28/2022 1:22 AM
This article overviews why during the upgrade process or installation it got stuck while installing NPcap.
Related error:
An unhandled win32 exception occurred in NPFInstall.exe (6656)
Just-In-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled. In Visual Studio, Just-In-Time debugging can be enabled from tools/option/debugging/just-in-time
Server Application Monitor
there is a third party tool install in the Orion server that use Just-In-Time debugging. Check if AlertLogic installed.
Resolution 1:
  1. Go to services.msc
  2. Check if AlertLogic service is running
  3. Stop the service
  4. Re-run the Installer
Resolution 2:
  1. Go to Programs and Features
  2. Uninstall NPcap
  3. Re-run the installer for the poller.
