Installation issues when deploying Agents in offline environment
When you are deploying an Orion Agent on a Windows Server 2008 R2 SP1 or Windows 7 SP1 without an active Internet connection, the installation fails. Follow the workaround steps suggested by Microsoft.
A certificate chain could not be built to a trusted root authority.
This issue also applies to Windows 7 SP1.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
