Innovative Circuit Technology UPC setup
OIDs must be added manually to monitor some manufacturer attributes in NPM.
12/17/2019 8:22 PM
2/25/2025 10:40 AM
This article gives a link to the OIDs needed to monitor ICT Innovative Circuit Technology UPC backup battery devices.
Network Performance Monitor
The manufacturer link below contains the OIDs in anExcel file. These OIDs can be added to the UNDP manually to allow NPM to monitor Innovative Circuit Technology devices.
http://www.ict-power.com/wp-content/uploads/2018/03/ict_snmp_mib_files.zip
(© 2020 <Innovative Circuit Technology>, available at <https://ict-power.com/>, obtained on <12 17, 2019>)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
