Tools
Initialization error during upgrade of Web Help Desk
During the upgrade of Web Help Desk to 2026.2.1.x, an error was encountered that prevented the database upgrade from completing. The upgrade is recovering the Web Help Desk configuration, but is getting and Initialization Eroor.
The upgrade error means Liquibase thinks there are two baseline changesets in 2026.1-baseline-complete.xml were modified after they already ran (checksum mismatch), so it refuses to continue.
The error means Liquibase thinks two baseline changesets in 2026.1-baseline-complete.xml were modified after they already ran (checksum mismatch), so it refuses to continue.
Run the script that corresponds to the applicable database. Each script applies the two MD5SUM corrections within a single transaction.
Before running the script:
- Take a full database backup, or at a minimum, back up the DATABASECHANGELOG table.
- Stop the Web Help Desk (WHD) service.
- Run the script using the database user account that owns the WHD schema.
MySQL
-- Apply the corrections in a single transaction.
START TRANSACTION;
SET SQL_SAFE_UPDATES = 0; -- include this only if safe-update mode is on
UPDATE DATABASECHANGELOG
SET MD5SUM = '9:30263ca4482ea84a0de85440e62a5fe1'
WHERE ID = '1771864125027-5'
AND AUTHOR = 'Web Help Desk'
AND FILENAME = 'db/changelog/baseline/2026.1-baseline-complete.xml';
SET MD5SUM = '9:f457c0be815073c655b9be7672561750'
WHERE ID = '1771864125027-136'
COMMIT;
PostgreSQL
BEGIN;
UPDATE databasechangelog
SET md5sum = '9:30263ca4482ea84a0de85440e62a5fe1'
WHERE id = '1771864125027-5'
AND author = 'Web Help Desk'
AND filename = 'db/changelog/baseline/2026.1-baseline-complete.xml';
SET md5sum = '9:f457c0be815073c655b9be7672561750'
WHERE id = '1771864125027-136'
COMMIT;
Microsoft SQL Server
-- Apply the corrections in a single transaction. XACT_ABORT ensures a
-- rollback if anything unexpected happens.
SET XACT_ABORT ON;
BEGIN TRANSACTION;
UPDATE dbo.DATABASECHANGELOG
IF @@ROWCOUNT <> 1
BEGIN
ROLLBACK TRANSACTION;
RAISERROR('Expected 1 row updated for 1771864125027-5. Rolled back.', 16, 1);
RETURN;
END
IF @@ROWCOUNT <> 1
BEGIN
RAISERROR('Expected 1 row updated for 1771864125027-136. Rolled back.', 16, 1);
RETURN;
END
COMMIT TRANSACTION;
GO
- Click Retry
