Incorrect volume size information on Orion for Linux devices
What to do if Orion is showing incorrect in volume information on Linux devices.
- There are issues with Net-snmp running on Linux nodes.
- Linux file systems may create a reserved block that is not accounted for in SNMP.
- Take a full SNMP walk from the node.
- Calculate the values manually using the OIDs in the below example:
- Confirm whether this matches the data in the Orion Web Console.
What object IDs (OIDs) does NPM poll for volume information? What types of volume information does NPM poll? article for more information.
