Incorrect interface speed on the Orion Web Console
What to do if the your Orion Platform product is reporting incorrect interface speed. It should be 1 Gb.
10/11/2018 4:29 PM
2/17/2022 6:50 AM
Your Orion Platform product is reporting an incorrect interface speed. It should be 1 Gb.
Orion Platform
Device itself is report low if-speed for subinterfaces see the results below for each interface speed configured under the device OID's
if-Name
If-speed
.1.3.6.1.2.1.2.2.1.2.1 = STRING: "lo"
.1.3.6.1.2.1.2.2.1.5.1 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.2 = STRING: "eth0"
.1.3.6.1.2.1.2.2.1.5.2 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.3 = STRING: "eth1"
.1.3.6.1.2.1.2.2.1.5.3 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.4 = STRING: "eth2"
.1.3.6.1.2.1.2.2.1.5.4 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.5 = STRING: "eth3"
.1.3.6.1.2.1.2.2.1.5.5 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.6 = STRING: "eth4"
.1.3.6.1.2.1.2.2.1.5.6 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.7 = STRING: "eth5"
.1.3.6.1.2.1.2.2.1.5.7 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.8 = STRING: "eth6"
.1.3.6.1.2.1.2.2.1.5.8 = GAUGE32: 1000000000
.1.3.6.1.2.1.2.2.1.2.9 = STRING: "eth6.580"
.1.3.6.1.2.1.2.2.1.5.9 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.10 = STRING: "eth6.581"
.1.3.6.1.2.1.2.2.1.5.10 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.11 = STRING: "eth6.582"
.1.3.6.1.2.1.2.2.1.5.11 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.12 = STRING: "eth1.313"
.1.3.6.1.2.1.2.2.1.5.12 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.13 = STRING: "eth6.583"
.1.3.6.1.2.1.2.2.1.5.13 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.14 = STRING: "eth1.314"
.1.3.6.1.2.1.2.2.1.5.14 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.15 = STRING: "eth3.386"
.1.3.6.1.2.1.2.2.1.5.15 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.16 = STRING: "eth3.387"
.1.3.6.1.2.1.2.2.1.5.16 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.17 = STRING: "eth0.30"
.1.3.6.1.2.1.2.2.1.5.17 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.18 = STRING: "eth0.40"
.1.3.6.1.2.1.2.2.1.5.18 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.19 = STRING: "eth5.570"
.1.3.6.1.2.1.2.2.1.5.19 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.20 = STRING: "eth5.571"
.1.3.6.1.2.1.2.2.1.5.20 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.21 = STRING: "eth5.572"
.1.3.6.1.2.1.2.2.1.5.21 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.22 = STRING: "eth5.573"
.1.3.6.1.2.1.2.2.1.5.22 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.23 = STRING: "eth5.574"
.1.3.6.1.2.1.2.2.1.5.23 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.24 = STRING: "eth5.575"
.1.3.6.1.2.1.2.2.1.5.24 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.25 = STRING: "eth5.576"
.1.3.6.1.2.1.2.2.1.5.25 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.26 = STRING: "eth0.10"
.1.3.6.1.2.1.2.2.1.5.26 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.27 = STRING: "eth6.577"
.1.3.6.1.2.1.2.2.1.5.27 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.28 = STRING: "eth6.578"
.1.3.6.1.2.1.2.2.1.5.28 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.29 = STRING: "eth6.579"
.1.3.6.1.2.1.2.2.1.5.29 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.30 = STRING: "eth0.20"
.1.3.6.1.2.1.2.2.1.5.30 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.31 = STRING: "eth2.384"
.1.3.6.1.2.1.2.2.1.5.31 = GAUGE32: 10000000
.1.3.6.1.2.1.2.2.1.2.32 = STRING: "eth2.385"
.1.3.6.1.2.1.2.2.1.5.32 = GAUGE32: 10000000
  1. You can manually change the "Custom Bandwidth" on each interface .
    Go to the interface > Edit Interface > Check "Custom Bandwidth" > set value as required > Submit
