Tools
Importing users from Active Directory into Dameware does not import all users from a group
What to do if you are importing users from Active Directory into Dameware, and not all users from a group are imported.
Active Directory Requirements
- Dameware Mobile Client, Mini Remote Control, and Exporter must be installed on a domain workstation, and run under a domain user.
- Dameware Central Server must be installed on a domain workstation.
- NTLM/NTLMv2 traffic and Kerberos authentication must be enabled.
- You must synchronize domain users into Dameware Central Server
- Open the Dameware Administration Console.
- Select Central Server > Users.
- On the Action toolbar, click AD User Import.
- Click Synchronized Import, and click Next.
- Click Custom Domain Controller, complete the fields, and click Next.
- Select the group you want to import.
- After the import complete, verify that the missing users were added.
