Importing Alerts containing SQL macro variables fails in the SolarWinds Platform 2022.1 and newer
When importing an alert containing SQL macro variables, the import fails with a permissions-related error.
2/6/2023 5:25 PM
2/20/2025 9:41 PM
Attempting to import an alert with SQL in it will fail with the following error:
Alert import failed with error: Account is not permitted to import SQL based Alert or Alert contains SQL variables
This error message occurs regardless of permissions level, even if the user is an admin in the SolarWinds platform.
Orion Platform
Known issue with importing alerts.
This issue is addressed in SolarWinds Platform 2023.1.1 and the release notes are here:
SolarWinds Platform 2023.1.1 Release Notes
Please upgrade your environment to this version with the steps here:
Perform a centralized upgrade of an existing deployment
