Ignore site-to-site tunnel errors for ASA tunnels
When a monitored Cisco ASA device reports an error for a pair of source-target endpoints, the VPN Site-to-Site tunnel is marked as Down in the Orion Web Console. You can specify a list of errors that are not reflected in the tunnel's status. Learn more about ignoring site-to-site tunnel errors for ASAs monitored with SolarWinds Network Performance Monitor (NPM).
When a monitored ASA device reports an error for a pair of source-target endpoints, the VPN Site-to-Site tunnel is marked as Down in the Orion Web Console. You can specify a list of errors that are not reflected in the tunnel's status.
- Log in to the Orion Web Console, and go to Advanced Configuration by typing the following address to your browser:
<ip address of your orion:port>/Orion/Admin/AdvancedConfiguration/global.aspx - Enter the error codes for phase 1 errors you want to ignore into the ASA.ASAIgnoredPhaseOneErrors field.
These values are polled by the following OID:
cikeFailReason 1.3.6.1.4.1.9.9.171.1.5.2.1.1.2ERROR CODE (IKE) DESCRIPTION 1 other 2 peer delete request was received 3 contact with peer was lost 4 local failure occurred 5 authentication failure 6 hash validation failure 7 encryption failure 8 internal error occurred 9 system capacity failure 10 proposal failure 11 peer's certificate is unavailable 12 peer's certificate was found invalid 13 local certificate expired 14 certificate revoke list (crl) failure 15 peer encoding error 16 non-existent security association 17 operator requested termination
- Enter the error codes for phase 2 errors you want to ignore into the ASA.ASAIgnoredPhaseTwoErrors field.
ERROR CODE (IPSEC) DESCRIPTION 1 other 2 internal error occurred 3 peer encoding error 4 proposal failure 5 protocol use failure 6 non-existent security association 7 decryption failure 8 encryption failure 9 inbound authentication failure 10 outbound authentication failure 11 compression failure 12 system capacity failure 13 peer delete request was received 14 contact with peer was lost 15 sequence number rolled over 16 operator requested termination - Save the Advanced Configuration settings.
When the monitored ASAs report phase 1 and phase 2 errors specified in the Advanced Configuration, the ASAs do not display as down in the Orion Web Console. The specified errors are ignored.
Note:
It is not possible to remove the VPN's which have a status of down
- Failed or down VPNs are polled from the device using SNMP via the cikeFailTable (1.3.6.1.4.1.9.9.171.1.5.2.1) and cipSecFailTable (1.3.6.1.4.1.9.9.171.1.5.3.1).
- We poll these entire tables in order to get individual VPN status.
- Cisco has implemented these tables as a sliding window in which only the last 'X' entries are maintained.
- The maximum number of entries for this table is specified by the cipSecFailTableSize (1.3.6.1.4.1.9.9.171.1.5.1.1.1) object which is typically 50
- So this means where there is more than 50 failed VPNs, the oldest one will be removed from FailTable on the device and with next poll will also removed from the list in NPM.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
