Tools
Deploy the SolarWinds Discovery Agent using a domain logon script in Service Desk
This article provides step-by-step instructions for deploying the SolarWinds Discovery Agent across multiple Windows computers using a domain logon script. The goal is to automate installation so the agent runs when users log into their domain-connected machines.
Deploying the SolarWinds Discovery Agent using a domain logon script allows organizations to automate agent installation across multiple Windows machines. This method ensures that the agent is silently installed whenever a user logs in to a domain-joined computer, eliminating the need for manual setup.
Key Steps:
- Download the Discovery Agent installer from the SolarWinds Service Desk.
- Place the installer in a shared network folder
- Create a batch script that installs the agent silently.
- Assign the script as a logon script via Group Policy in Active Directory.
- Test and validate installation on target machines.
Before proceeding, please review the official documentation: Agent installation for mass deployment
Step 1: Download the SolarWinds Discovery Agent Installer
- Navigate to Setup → Discovery & Assets → Installation
- Download the SolarWinds Discovery Agent for Windows (EXE file)
- The file name should be: Solarwinds_Discovery_Agent_{version}_installer.exe
Step 2: Move the Installer to a Shared Network Folder (Recommended: NETLOGON)
NETLOGON folder is a special shared directory on a domain controller used for storing logon scripts and policies for domain users.
Shared network path (UNC):
\\YourDomainController\NETLOGON\
Example:
\\DC01\NETLOGON
Important Note: Make sure this folder is accessible to all domain users with read permissions.
Step 3: Create the Batch Script
Create a .bat file (e.g., install_solarwinds_agent.bat) with the following code:
@echo off
REM === Agent already deployed on the computer?
if exist "C:\Program Files\Solarwinds Discovery Agent\agent\src\mini_kernel\service.*" goto END
if exist "C:\Program Files (x86)\Solarwinds Discovery Agent\agent\src\mini_kernel\service.*" goto END
REM === Deploying agent in silent mode
"\\YourServer\Software\Solarwinds\Solarwinds_Discovery_Agent_{version}_installer.exe" --mode unattended
REM === Script done
:END
Replace \\YourServer\Software\Solarwinds\ with the actual UNC path to your installer.
Step 4: Store the Script in NETLOGON
Copy your .bat file to:
Step 5: Assign the Logon Script via Group Policy
- Open the Group Policy Management Console on your domain controller.
- Right-click on your target OU (where your users are), and choose Create a GPO (or use an existing one).
- Name it something like: Deploy SolarWinds Discovery Agent
- Right-click the GPO → Edit
- Go to: User Configuration → Policies → Windows Settings → Scripts (Logon)
- Double-click Logon → Click Add
- Browse and select the script file from \\YourDomainController\NETLOGON\
Step 6: Update and Test
On a test machine:
- Run gpupdate /force
- Log off and log back in (or restart)
- The script should install the agent silently
If you’ve completed all the steps and are still experiencing issues, please reach out to the Technical Support Team at technicalsupport@solarwinds.com.
