IP VRF LIIN-VRF config comparison issue with Cisco 4500X in NCM
When comparing the running config and startup config of Cisco 4500X, the running config has an additional value "ip vrf Liin-vrf".
When comparing the running config and startup config of Cisco 4500X, the Running config has a value below "ip vrf Liin-vrf".
To resolve this, access NCM Configs settings and you can then create, edit, enable, disable, or delete a regular expression:
- Click Settings > All Settings.
- Under Product Specific Settings, clickNCM Settings.
- Under Configs, click Comparison Criteria.
- Click Add New.
- Enter a title, and write the regular expression below:
^ip vrf Liin-vrf
- Select Enable NCM to ignore this pattern when comparing config files.
- Click OK.
You need to do steps 4 to 7again to add a new Comparison Criteria again for the expression below:
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
