IIS handler mapping requirements
This article lists the file extensions that IIS must allow in order for Orion Platform or SolarWinds Platform products to function. The article contains a list of extensions you need to allow when you use request filtering in IIS.
For details, see the Setup section in the File Name Extensions <fileExtensions> topic in the Microsoft documentation (© 2020, Microsoft, available at https://docs.microsoft.com/en-us/iis/configuration/system.webserver/security/requestfiltering/fileextensions/, obtained on <November 30, 2020).
Website
..ascx
.ashx
.asmx
.aspx
.axd
.css
.gif
.htm
.html
.ico
.jpg
.js
.png
.svg
.ttf
.woff
.woff2
.xml
Imports/Exports
.apm-template.csv
.json
.template
.txt
.xls
.xlsx
.xml
Installer
.cab.exe
.json
.msi
.msp
.opkg
.xml
.zip
For Handler Mappings, the IAO must document and approve all file extensions the website allows and denies. The allow and deny extensions will be compared to the Handler Mappings in IIS. Handler Mappings at the site level take precedence over Handler Mappings at the server level.
