Applications Systems
IBM Informix ODBC driver issue
Connection string does not matter at such stage, because the error is about the driver. Error: Test Failed with "Down" status on xxxxx Data Source name not found and no default driver specified. This article provides brief information and steps to resolve the issue when you cannot get the IBM Informix ODBC driver to load after trying the instructions using the IBM Informix SAM template.
11/16/2018 7:24 PM
4/1/2020 3:45 PM
This article provides brief information and steps to resolve the issue when you cannot the IBM Informix ODBC driver to load after trying the instructions from the following pages using the IBM Informix SAM template:
The OBDC works fine. Connection string does not matter at such stage, because the error is about the driver.
Error:
Server Application Monitor
The issue is caused by wrong driver.
  1. Uninstall any IBM client SDK driver software.
  2. Download this specific one from here
  3. Download clientsdk.4.10.TC6DE.WIN.zip.
  4. Extract ZIP.
  5. Install installclientsdk.exe.
  6. Select only the "IBM Informix ODBC Driver" in Features.
  7. Regedit > HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ODBC\ODBCINST.INI\IBM INFORMIX ODBC DRIVER.
  8.  Driver Key should equal install path. Default - C:\Program Files (x86)\IBM Informix Client SDK\bin\iclit09b.dll.
  9. Environmental Variable:
  10. Variable Name: Path
  11. Variable Value: C:\Program Files (x86)\IBM Informix Client SDK\bin; etc...
  12. Leave application monitor edit > advanced to x86.
