Applications Systems
Hyper-V did not find virtual machines to import from location
When installing Virtualization Manger on Microsoft Hyper -V server, you are prompted with an error "Hyper-V did not find virtual machines to import from location".
10/10/2018 6:42 PM
10/10/2018 6:56 PM
When installing Virtualization Manager on Microsoft Hyper -V server, you are prompted with an error Hyper-V did not find virtual machines to import from location, when you proceed with the following steps:
  1. Extract the contents of the Hyper-V .zip file.
  2. Launch the Hyper-V Manager.
  3. Connect to the appropriate Hyper-V server.
  4. In the Action menu, select Import Virtual Machine.
  5. Error prompt: Hyper-V did not find virtual machines to import from location...
  1. Log in as a local administrator.
  2. On the Hyper-V Manager, recreate a new virtual machine.
  3. Retry the steps to import the virtual machine.
