How to use SolarWinds Platform REST Walker
This article lists the steps to use the SolarWinds Platform Rest Walker diagnostic tool.
11/8/2018 10:01 PM
5/6/2026 5:58 PM
This article describes how to run the SolarWinds REST Walker.
This tool collects data using Representational State Transfer (REST) technology to gather API-specific data for investigation and testing purposes. The response is stored as a context.txt  file in the folder structure based on the request.
You can add technologies by implementing specific plug-ins. The required interfaces necessary for implementing a plug-in are described in this article.
Network Performance Monitor
  • Log in to the server hosting your SolarWinds Platform Application.
  • Navigate to installation folder.
    • DRIVE:\Program Files\SolarWinds\Orion
      • Prior to 2023.x: DRIVE: \Program Files (x86)\Solarwinds\Orion\RestWalker
      • 2023.x and beyond: DRIVE:\Program Files\Solarwinds\Orion\
  • Run the following application.
    • SolarWinds.RestWalkerWpfApp.exe
  • Select Output Directory.
  • Select the Plugin depending on type of device.
    • Cisco ACI
    • Arista Wireless Manager
    • Aruba EdgeConnect
    • Aruba Central
    • GCP Plugin
    • Azure
    • Dell Power Store
    • Extreme Cloud IQ
    • F5 iControl
    • Fortinet Cloud
    • FortinetFortiManager
    • Google Cloud Platform
    • HPE Nimble/Alletra 5000
    • HPE GreenLake For Block/Alletra 9000/Primera (WSAPI)
    • Juniper Mist
    • Meraki Cloud
    • NetApp E-Series - SANtricity Web Services API
    • Net App Ontap REST Api
    • Palo Alto
    • Prisma
    • Ruckus One
    • Ruckus SmartZone
    • VeloCloud
    • Viptela
  • Choose the certificate validation.
    • Full
    • Base
    • IgnoreAll
  • In the Location, enter the URL or the IP address of the management URL.
  • Enter the Credentials used for authentication.
  • Click Collect Walk.
    • NOTE: The tool automatically creates a ZIP file in the Output directory.
  • Send the ZIP file to SolarWinds Technical Support.
TROUBLESHOOTING
REST Walker saves its logs file in c:\ProgramData\SolarWinds\Logs\Orion\ in files named RestWalker.log(*).
