How to unmanage Nodes, Interfaces and/or Applications in bulk in Orion products.
This article provides steps on how to unmanage Nodes, Interfaces and/or Applications in bulk using the Orion Web Console.
11/29/2018 10:30 PM
1/5/2023 1:34 PM
The Nodes, interfaces, and applications can all be unmanaged individually in the web console, and can also be unmanaged and managed in bulk using the Manage Nodes page, and the Manage Application Monitors pages of the Orion Web Console.
Orion Platform
Unmanage Nodes
  1. Go to Settings > Manage Nodes (NOTE: This option will only show if the product license is active and user has permission to Manage Nodes)
  2. Ensure that the Show: Nodes
  3. Select all nodes you wish to Unmanage
  4. Click Maintenance Mode > Unmanage Now
Unmanage Interfaces
  2. Ensure that the Show: Interfaces
  3. Select all Interfaces you wish to unmanage
Unmanage Applications
  1. Go to Settings > All Settings > SAM Settings
  2. Click Manage Application Monitors
  3. Select the Applications you wish to unmanage
For information on how to unmanage Nodes, Interfaces or Applications on a scheduled basis using the Unmanage Scheduling Utility, please see Configure Orion to unmanage items on a scheduled basis.
There is no supported way to bulk-unmanage virtual machines in an AWS or Azure environment.
