Applications Systems
How to unmanage Application pool in AppInsight for IIS in SAM
This article will show the steps in unmanaging application pool in AppInsight for IIS in SAM.
11/18/2021 1:32 PM
4/9/2025 6:56 PM
This article will provide a step-by-step procedure on unmanaging application pools in AppInsight for IIS in SAM.
Server Application Monitor
Please follow the steps to successfully unmanage an application pool in AppInsight for IIS.
1. Access your AppInsights for IIS
  1. Go to Settings > All Settings.
  2. On the PRODUCT SPECIFIC SETTINGS select SAM Settings.
  3. Locate APPLICATION MONITORS and click on Manage Application Monitors.
  4. Select AppInsight for IIS on the Application Monitor Sidebar.
  6. On the IIS Application Details, locate the Application Pool.
7. Select the Application you intend to remove/ unmanage.
8. Click Unmanage Application Pool.
