Security Compliance
How to uninstall Malwarebytes using Patch Manager
This article describes how to uninstall Malwarebytes 3 using Patch Manager.
You can remove Malwarebytes by:
- Run
MBAM-Clean.exeprovided by Malwarebytes in Silent Mode. - Create a separate package.
- Modify the random installer package.
Run the Malwarebytes utility
Run MBAM-Clean.exe uninstaller provided by Malwarebytes in Silent Mode.
- Create a separate package with the uninstaller using Silent Mode.
- Deploy
Modify the random installer package by using PackageBoot in Patch Manager, adding before applying packageor after applying package to run MBAM-Clean.exe.
If Silent Mode is available, the software automatically replaces the old version with the new version when deploying the new package.
If Silent Mode is not available, the software runs the application on each machine, but you must manually perform the uninstall procedure.
See the following resources for details:
