Tools
How to show remote cursor while on a remote session for Dameware Remote Everywhere
Steps for showing the remote cursor while already on a remote session for Dameware Remote Everywhere
4/5/2019 7:17 PM
4/5/2019 7:17 PM
  • I need to know when my partner is moving the remote cursor around to avoid catching them by surprise, how can I view their cursor's location?
While performing a Remote Session:
  1. Navigate to the Remote Desktop tab.
  2. Click on the drop-down menu to the right of Remote Desktop (looks like a downward facing arrow).
  3. Click the menu View, first option in the drop-down menu.
  4. Select the option Show Remote Cursor.
    • Alternatively, you can use SHIFT + CTRL + T as a keyboard shortcut to toggle this option on/off.
