How to select specific row on using Custom poller on Orion web console
Custom poller returned several values but user would only want to extract certain value
11/14/2019 5:04 AM
11/14/2019 5:04 AM
User is trying to create a custom poller for CPU/Memory on Orion web console.
However, the Memory Poller table is returning 2 values. User would only like to use the first value polled.
Network Performance Monitor
The OID '1.3.6.1.4.1.9.9.221.1.1.1.1.18' polls the entire memory table.
1. Run SolarWinds SNMP Walk to the device that you would like to assigned the poller to.
2. Open the SNMPwalk and locate the exact OID that returns the value
3. Create Custom poller on Orion web console
4. On the Pick Object Identifier screen, scroll down and check the 'Looking for an OID that doesn't exist in our database? It could be brand new!' and input the exact OID to poll.
