How to round up percentage to whole numbers in a volume alert message in NPM
By default, the variable returning volume percent used returns five decimal places. To round the percent usage of a volume, use the variable in the newer format and add the % character.
5/25/2020 7:02 AM
5/25/2020 7:02 AM
To round the value for the percentage of used space on a volume in an an alert action message (instead of displaying the value with five decimal spaces), change the variable in the alert action message.
Orion Platform
  1. On the Orion Web Console, click Alerts&Activity > Alerts, and then click Manage Alerts in the upper right corner of the screen.
  2. Select the alert, click Edit Alert, and go to the Trigger Actions tab. See Define what happens when an alert is triggered in the Orion Platform.
  3. Click Edit the alert action and expand the Message section.
  4. Replace the variable for volume percent used ${VolumePercentUsed} with its newer format:  ${N=SwisEntity;M=VolumePercentUsed;F=Bytes} %
The percent information in the alert message will be rounded to whole numbers.
