Tools
How to permanently delete tickets in Web Help Desk
This article explains how to permanently delete tickets in Web Help Desk.
This article describes how you can permanently delete tickets in Web Help Desk by enabling the Secure-delete Tickets option.
When this option is enabled and you delete a ticket, the system physically removes the ticket from the database instead of marking the ticket as Deleted. When the ticket is deleted, the following ticket-related items are also deleted:
- Attachments
- Client notes
- Tech notes
- Ticket history entries
- Email history
- All Web Help Desk versions
- Log in to Web Help Desk.
- Click Setup > Techs and select your Admin account.
- Under Ticket Setup, locate the Secure-delete Tickets field.
If Secure-delete is disabled, the field value is No.
If secure-delete is enabled, the field value includes a selected checkbox.
Enable Secure-delete Tickets
- Click the pencil icon at the top of the window.
- Select the Secure-delete-Tickets checkbox.
- Click Save.
- Secure-delete tickets is enabled.
After you remove the targeted tickets, you can return to Ticket Setup and disable this option.
