How to move Groups/Supernets and Subnets to another location using IPAM new GUI
This article will show you the step-by-step process on how to move Groups/Supernets and Subnets to another location using IPAM new GUI
9/22/2025 4:24 PM
9/22/2025 5:30 PM
Starting in IPAM 2025.2, a new GUI for IPAM was implemented,  and there is now a new option to "Move" the Groups/Supernets and Subnets to another location, rather than manually dragging them to your desired location.
IP Address Manager
Step 1:
Click on MY DASHBOARDS > IP ADDRESSES, click "Manage Subnets & IP Addresses.
Step 2:
Pick a Group/Supernets or Subnet that you want to move.
-For example, you want to move the whole supernet with Subnets to another Group, "Group Name 2".
-You have 2 options: you can use both right and left panes to move it.
-Click "Move"
Step 3:
A new window will pop up where you can pick the location.
-Example: Moving it to "Group Name 2".
-Click "Move"
Result:
-They are now on "Group Name 2".
