Applications Systems
How to monitor ports with SAM
TCP port monitor. How to monitor ports. Monitoring ports with Server & Application Monitor. Monitoring TCP ports.
8/17/2020 2:08 AM
12/20/2021 12:09 PM
How to monitor ports in Server & Application Monitor.
Server Application Monitor
Create a new SAM template containing a TCP port monitor.
  1. Log into the Orion web console
  2. Settings > All Settings > SAM Settings > Create New Template
  3. Name the template a unique name
  4. Add a component monitor to your template
  5. Choose the TCP port monitor
  6. Configure the port number
  7. Click the submit button at the bottom of the page
Assign this new template to a desired server.
