Tools
How to mitigate SolarWinds Web Help Desk (WHD) against Java4Shell CVE-2026-114938
In 2026, the National Institute of Standards and Technology (NIST) published security bulletins about the following CVE-2026-114938.
In 2026, the National Institute of Standards and Technology (NIST) published a security bulletin about CVE-2026-114938, a vulnerability affecting Spring Framework.
CVE-2026-114938, is an vulnerability in Java that allows unauthenticated attacker with network access via multiple protocols to compromise Oracle Java SE, Oracle GraalVM for JDK, Oracle GraalVM Enterprise Edition. Successful attacks of this vulnerability can result in takeover of Oracle Java SE, Oracle GraalVM for JDK, Oracle GraalVM Enterprise Edition. Note: This vulnerability can only be exploited by supplying data to APIs in the specified Component without using Untrusted Java Web Start applications or Untrusted Java applets, such as through a web service.
SolarWinds Web Help Desk versions running 12.x and earlier are not affected since they use a Java version that is outside the range of affected Java versions.
Web Help Desk 2026.2.1 on Windows
In Web Help Desk 2026.2.1, JVM options are configured in the backend startup files—not in whd.conf or a JAVA_OPTS variable.
- Sign in to the WHD server with an account that can administer the service and edit the WHD installation files.
- Back up
<WHD_HOME>\bin\run-backend-with-env.bat. - Open
<WHD_HOME>\bin\run-backend-with-env.batin a text editor. - Append the option to the existing JVM_ARGS setting. If there is no existing setting, add the line below before the Java command is launched:
set "JVM_ARGS=%JVM_ARGS% -XX:-UseBASE64Intrinsics" - Do not replace other JVM arguments already in JVM_ARGS. Save the file.
Web Help Desk 2026.2.1 on Linux
- Back up /opt/webhelpdesk/service/whd-backend.service.
- Open /opt/webhelpdesk/service/whd-backend.service in text editor.
- Append the JVM argument in ExecStart.
For example, on Linux, add a custom JVM property in ExecStart:
ExecStart=/opt/webhelpdesk/bin/jre/bin/java \
-XX:-UseBASE64Intrinsics \
(All other ExecStart args remain unchanged.)
Web Help Desk 2026.2.1 on Mac
- Back up /opt/webhelpdesk/service/macos/com.solarwinds.whd.backend.plist.
- Open /opt/webhelpdesk/service/macos/com.solarwinds.whd.backend.plist in text editor.
- Append the JVM argument (in EnvironmentVariables):
in JAVA_TOOL_OPTIONS
- Append the value from <string>-Xms256m -Xmx1024m</string> to <string>-Xms256m -Xmx1024m -XX:-UseBASE64Intrinsics</string>
Restart and verify
- After saving the change, restart the Web Help Desk services.
- Confirm that the service is running, then review the Web Help Desk backend startup log for JVM startup errors. If the JVM reports that UseBASE64Intrinsics is unrecognized, remove the option and restart the service.
