Tools
How to log in to Web Help Desk using Google G-Suite
This article explains how to log in to Web Help Desk using Google G-Suite.
1) Set up your custom SAML application in the Google Admin Console
See Set up your own custom SAML application on the Google Support site to create a custom SAML app to log in to Web Help Desk using SSO (© 2019 Google LLC, available at https://support.google.com/, obtained on February 1, 2019).
When you set up your custom SAML app, use the following settings:
- When you set up your Google idP information, click Download in Option 1.
- When you complete the basic information for your custom app, enter WHD as the application name.
- When you enter your service provider information:
- Enter the following URL for the ACS URL and Entity ID:
https://<domain>/helpdesk/WebObjects/Helpdesk.woa - In the Name ID field, select Basic Information and Primary Email.
- In the Name ID Format field, select UNSPECIFIED.
- Do not add any changes to Attributive Mapping.
When you turn on SSO to your new SAML app, use the following settings:
- In the Google Admin Console:
- Locate the WHD app and change the certificate setting to On for everyone.
- Click the WHD icon, click the Edit icon in the top right corner, and copy the URL. The format should be:
https://accounts.google.com/o/saml2/initsso?idpid-xxxxxxxxx&spid=xxxxxxxxxxxx&forceauthn=false
wherexxxequals your unique values.
2) Set up your Web Help Desk Administrator Console
a) Temporarily disable LDAP synchronization
- Log in to the Web Help Desk Administrator Console as an administrator.
- Click Setup > Clients > AD / LDAP Connections.
- Click the appropriate connection or create a new connection.
- Click the Edit
icon.
- In the Connection Basics tab, uncheck Enabled, and then click Save.
b) Link Web Help Desk to Google Apps
- Click General > Authentication.
- Click the Authentication Method drop-down menu and select SAML 2.0.
- In the Sign-in page URL, paste the URL you copied in the Google Admin Console when you turned on SSO.
For example:https://accounts.google.com/o/saml2/initsso?idpid-xxxxxxxxx&spid=xxxxxxxxxxxx&forceauthn=false
where
xxxequals your unique values. - Next to the Verification certificate, click Upload.
- Locate and select the certificate you downloaded when you set up your custom SAML app.
- Click Save.
c) Update the client user names
Google G-Suite does not recognize the username or SAM-Account-Names format used in Web Help Desk—only email addresses. As a result, change the user names of all clients in the Web Help Desk Administrator Console from user names to full e-mail addresses.
- In the console, click Clients.
- Change the user names to their corresponding email addresses.
- Save your changes.
d) Re-enable LDAP synchronization
- In the Web Help Desk Administrator Console, click Setup > Clients > AD / LDAP Connections.
- Click the appropriate connection.
- Click the Edit icon.
- In the Connection Basics tab, select Enabled.
- Click Save.
e) Update the attribute mappings
- Click the Attribute Mappings tab.
- Click the Edit
icon.
- In the Schema row, select Custom and enter
accountin the field. - In the Username Attribute field, enter
mail. - In the Name Attribute(s) row, enter
givenNamein the First Name field andsnin the Last Name field. - In the E-Mail Attribute field, enter
mail. - Click Save.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
