Tools
How to gather Diagnostic Logs for Kiwi CatTools
This article describes how you can get Diagnostics logs for Kiwi CatTools.
These logs will assist us in rapidly diagnosing your issue.
2. Open the Kiwi CatTools
3. On the activities pane select Stop Timer.
4. In Kiwi CatTools navigate to File and select Enable capture mode
5. Select the impacted activity and click the Run now button
7. A prompt message will appear that will give you options to select what diagnostics files you want to create. Select the files that you want to create and choose
8. Next option will provide you the option to select the device that you want to capture logs to be included and variation files that you want to include. Once you have selected the capture logs and the variation files please select "Create".
9. After selecting the "Create Tab" a message prompt like the image below will appear. This indicates that a file TechSupport.zip is successfully created.
10. The file is located in the folder C:\Program Files (x86)\CatTools3\Reports
11. Send the file to our Technical Support team when creating a ticket so that they can have information about the issues that you have on your Kiwi CatTools Application.
