How to forward incoming SNMP trap messages to another server
This article describes how to forward incoming SNMP trap messages received by a SolarWinds server to a secondary management server (such as Kiwi Syslog).
This article describes how to forward incoming SNMP trap messages received by a SolarWinds server to a secondary management server (such as Kiwi Syslog Server) with the Orion Trap Viewer.
Note: If you have the Orion Log Analyzer instead of the legacy Trap Viewer, you can use Log Analyzer to forward messages .
TCP port 162 is reserved to listen for incoming trap messages from monitored devices within a SolarWinds deployment. After the messages are processed by the SolarWinds server, you can forward the messages to a secondary server.
If you are unable to receive trap messages from your targeted devices, see How to verify if SNMP traps are received by your Orion server
- Log in to the targeted SolarWinds server.
- Open the Trap Viewer.
- Click the yellow warning icon in the menu bar and select Add Rule.
- In the Rule Name field, enter a name for the new rule.
- Enter the IP addresses that will be forwarded to the secondary server.
Enter [ * ] to apply this rule to all trap messages. - Click the Alert Actions tab.
- Click Add Action and select Forward the Trap.
- Enter the hostname or IP Address of the secondary server that receives the incoming trap message.
- Select any additional options, and then click OK.
